Check around on the Mustang forums. I know this topic has been discussed before on sites like ModdedMustangs.com and I remember there being some good information there. From what I can remember there are a few differences between the truck and car 4.6. Also if I remember correctly the 98 will be NPI and the 2002 will be PI, so you might be looking at an increase in HP.
Not sure on this particular engine but a lot of times they use a different cam to increase low end torque on the truck engine.
ALL modulars use the same camshafts. Car, Truck, etc..they're ALL the same.
The only difference being NPI heads having a camshaft with less valve lift than the PI heads.
JL
