PB Blaster is not the King
Old Oct 31, 2009 | 08:55 AM
megawatt00's Avatar
megawatt00
I found this thread in the GA forum.
https://www.ford-trucks.com/forums/8...se-winner.html
It seems that a 50 50 mix of ATF and Acetone is the best for removing rusted bolts. I am very curious about this where as the salt from the roads here does a number on the under carriages of our trucks here. I am going to mix up a batch to use next time I have some wrenching to do. Any one else want to play mad scientist and post up the results?
Old Oct 31, 2009 | 09:11 AM
jcrammell's Avatar
jcrammell
Thanks for the info Jim. Reps to ya.
Old Oct 31, 2009 | 09:17 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I sell both in my store, so I will bring some home and see how it does.
Old Oct 31, 2009 | 09:21 AM
mechelement's Avatar
mechelement
Never heard of the ATF trick. I'd give it a shot.
When I lived in VT & NH, I'd always oil undercoat my vehicles and I'd spray my folks vehicles too. Just use bar and chain lube and mix it with a little used motor oil. Then spray underneath the truck. We used an air compressor syphon sprayer. It works great. After you spray, start the truck to warm up the exhaust and get the oil off of it, then take it down a dirt road. Just don't wash under the truck all winter. Come spring time, spray it off.
Old Oct 31, 2009 | 09:25 AM
nissandoc's Avatar
nissandoc
A friend of mine uses his old motor oil and sprays under his trucks and campers. He spends a lot of time at the beach and none of his stuff has any rust on them.
Old Oct 31, 2009 | 09:26 AM
Ponyboychris's Avatar
Ponyboychris
Let us know, Rick. Curious. I swear by PB Blaster but good to have another weapon to fight against #@!*^ stuck bolts.
Old Oct 31, 2009 | 09:32 AM
maevans's Avatar
maevans
I'll play.
I will mix some up and try it at work, also drop some off to my buddy who is a mechanic, let you know what I find.
Old Oct 31, 2009 | 09:33 AM
74baja's Avatar
74baja
My truck's undercarriage is already rusted pretty bad. PO put some crappy undercoating on and al it did was trap moisture and flake off. Great. Is there anything that can be done at this point? I haven't been losing sleep over it, is it something to worry about?
Old Oct 31, 2009 | 09:37 AM
nissandoc's Avatar
nissandoc
Zep sells a product called Zep Preserve that puts PB blaster to shame. I dont think its sold in stores.
indsupply.com - Industrial Supply
On a quick search this was all I found. It works great. I've used it for years.
Old Oct 31, 2009 | 09:48 AM
farmdad's Avatar
farmdad
I have used the mix using synthetic ATF and it works well. Haven't used it on extremely rusted bolts but it seemed to work quite quickly on what I had to loosen. Here is a table that I copied from a farm forum about it.
April 2007 issue of Machinist Workshop Magazine. They arranged a subjective test of all of the popular penetrants with the control being the torque required to remove the nut from a scientifically rusted environment.
Penetrant: Average Load:
none 516 ft lbs
WD40 238
PB Blaster 214
Liquid Wrench 127
Kano Kroil 106
ATF-Acetone mix 53
Some believe that synthetic ATF improves the mix still further.
That had to be one badly rusted or very large nut to require 516 ft/lb to loosen it. Most bolts would have twisted apart before reaching that torque.
Old Oct 31, 2009 | 09:55 AM
mechelement
Is that ATF mix dangerous to any rubber or plastic part that may be close to the rusted bolt or nut?
It works great, especially in high salt areas.
Old Oct 31, 2009 | 10:16 AM
farmdad's Avatar
farmdad
The acetone would probably be more damaging than the the ATF but I see what you are getting at. Probably wouldn't want to let it get on paint either or else wipe it off quickly.
Old Oct 31, 2009 | 10:19 AM
megawatt00's Avatar
megawatt00
I have used Acetone on a rag to remove the left over glue from decals on work trucks before with no bad results. All the trucks were white for what it is worth.
stormyrider's Avatar
stormyrider
Here on the farm we always have used ATF to free up rusty chains by soaking the chain in it overnight.
Old Oct 31, 2009 | 10:36 AM
PwerStroke99's Avatar
PwerStroke99
I used Penetrol by Schaeffers yesterday during my trans install. Seems to work really well.
