idle problems
Old Oct 30, 2009 | 11:06 PM
87f2504x4302's Avatar
87f2504x4302
idle problems
I have an 87 f250 with a 302. When the truck sets for a while I have to cycle the key for a few times to get it started. It acts like it is bleeding fuel pressure off.Once it is started it stays running but surges up and down.It runs great going down the road except when you shift it stays at a higher idle and when you give it gas right after you shift it will buck once or twice but thats it. I have cleaned the IAC, put new plugs,wires,fuel filter, air filter, IAT sensor. Seems not to surge quite as bad at idle but is still hard starting and bucks when you shift. I dont think it is the fuel pump because it does the same thing on both tanks. Any info would be greatly appreciated. <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
<!-- controls -->
Old Oct 31, 2009 | 06:13 AM
DBGrif91's Avatar
DBGrif91
Have you tried pulling any codes off it? See fordfuelinjection.com if you're not sure how to do it.
Old Nov 2, 2009 | 04:43 AM
sg1099's Avatar
sg1099
mine did that awhile back and it turned out to be 2 loose fuel lines.one at the fuel filter and one at the hard line coming from the rear tank. i noticed a drip,one single drip,when i was greasing the u-joints and that got me looking harder.hope it helps.
Old Nov 2, 2009 | 12:55 PM
rla2005's Avatar
rla2005
You need to check your fuel pressure with a gauge. That will eliminate a lot of guess work as well as checking for codes. No sense throwing money at an unknown problem.
