Sponsored by: Real Truck
ESOF issue
Old Oct 30, 2009 | 08:35 PM
freekyFX4's Avatar
freekyFX4
ESOF issue
My truck makes a noise when I turn the key to the ON position to let the glow plugs warm up. It sounds like there is a small compressor down in the left front wheel well. It only happens when my truck has not been driven for several hours. If I start the truck, then shut it off, then start it again, it does not happen. This is the same noise that I heard the other night when I shifted the truck to 4wd then back to 2wd. I was thinking that it was the ESOF, but I really don't understand how that works. Could it be losing air pressure? I really don't know the first thing about this, but I know it makes the sound when I start the truck in the morning and it makes it when I get off work. Thanks for the help.
Old Oct 30, 2009 | 08:43 PM
dchamberlain's Avatar
dchamberlain
What you are probably hearing is the electric vacuum pump. Vacuum is used to lock and unlock the front hub, as well as for heater controls. I'd say what you're hearing is normal.
Old Oct 30, 2009 | 08:45 PM
freekyFX4's Avatar
freekyFX4
Ok, thanks. That is exactly what it sounds like. An electric compressor, or in this case, vacuum pump. I appreciate the quick response. Mine did not used to do this, so I think I may be losing vacuum somwhere. Thanks again.
Old Oct 30, 2009 | 10:13 PM
onephinesuperduty's Avatar
onephinesuperduty
Sounds like the vac pump, also if you have a leak somewhere typically the hvac system defaults to defrost
