Broken Hose
Old Oct 30, 2009 | 11:25 AM
brett long's Avatar
brett long
Broken Hose
93 ford 150 with the 6 cylinder engine. There is a broken white plastic hose above the glove box in the engine compartment. Looks like it goes to a vacumm switch onto of a black box near the fender and hood and then goes into a black plastic wire holder then into the firewall. What is this hose and pump for?
Old Oct 30, 2009 | 11:37 AM
SparkyShaft's Avatar
SparkyShaft
The hose you are refering to goes to that vacuum switch that allows outside air to come into your truck that works with your A/C an vents as they are all vacuum controlled.
Old Oct 30, 2009 | 11:42 AM
brett long's Avatar
brett long
does it need to be replaced? I live in florida and the a/c is working fine.
Old Oct 30, 2009 | 12:02 PM
SparkyShaft
Yes I would fix it cause you will have a vacuum leak until its fixed, I would jus find some small hose to patch it with.
Old Oct 30, 2009 | 12:17 PM
brett long's Avatar
brett long
Thank you for your help!!
