Sponsored by: Real Truck
2001 Cab Difference 4x4 2x4
Old Oct 30, 2009 | 05:54 AM
tommypic's Avatar
tommypic
I have a 2001 F250 4x4 with 7.3 that rolled over on top . I was wanting to change cabs . I found a 99 F250 2x4 cab with 5.4 and title . I was wanting to the know the difference in the two cabs , I know wiring will be different just dont know about cab .
Old Oct 30, 2009 | 09:52 AM
2002 F350V10's Avatar
2002 F350V10
cab is the same.
Old Oct 30, 2009 | 02:51 PM
06silvercrew's Avatar
06silvercrew
Just keep in mind there is a difference between manual and automatic transmission cabs. Floor pan is dfferent.
Old Oct 30, 2009 | 05:03 PM
Car_Totem's Avatar
Car_Totem
Same cab
The 1999 to 2001 cab interchange is flawless. The floor pans are also the same. There is a plate that is screwed in when no manual 4X is being used. You will find 3 or 4 holes that need to be taped with threads if your putting a gasser body on a diesel chassis. Best to gut it down to bare steel inside and transfer as much as you can from your wrecked truck. Very little interchanges from the gas body. I'm putting the finishing touches on one now that was a 99 7.3L 4X4 that got a 2001 5.4L donor body. BE CAREFUL! The bodys weigh more that you might imagine. Keep your finger clear while setting it. A two post lift is ideal.
