6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
updated fuel filters
Old 10-29-2009, 07:50 PM
cheezit's Avatar
cheezit
cheezit is offline
just did a set of filters of an 08 that was in for repairs. there is an updated fuel filter for the frame mount pump. the new filter is now sealed with an oring to help reduce debris from entering the high pressure pump.
Old 10-29-2009, 08:22 PM
sdetweil's Avatar
sdetweil
sdetweil is offline
same part number? fd-4609?
Sam
Old 10-29-2009, 08:24 PM
cheezit's Avatar
cheezit
cheezit is offline
sorry sam I did not look at the short or long number. as a rule we techs just send a req with an item discription. and we get handed a part
Old 03-14-2010, 06:34 PM
Tom's Avatar
Tom
Tom is offline
BUMP!!!
I know, old post, but I wanted to mention that the updated filters have the same FD-4609 part number as the old ones did!
Just did mine on Wednesday, the frame mounted one SUCKS!
Old 03-15-2010, 04:52 AM
Eric326's Avatar
Eric326
Eric326 is offline
Since the newer filter has the same part number, has anyone confirmed that the filters being sold from www.dieselfiltersonline.com are the newer design ones? Or did you pick the filter up from the dealership?
Old 03-15-2010, 07:56 AM
Tom's Avatar
Tom
Tom is offline
Mine came from www.dieselfiltersonline.com
Ordered it in February, filters had an 11/2009 manufacture date.
Old 03-15-2010, 08:09 AM
Eric326's Avatar
Eric326
Eric326 is offline
Since Racor makes the Motorcraft fuel filters I wonder if Racor is shipping the updated design.
Old 03-15-2010, 08:28 AM
freekyFX4's Avatar
freekyFX4
freekyFX4 is offline
Does the kit at Ford 6.4 Liter Turbo Diesel Motorcraft FD-4609 Fuel/Water Seperator Filters(FD4609): Pick Up & Excursion include both filters or just the one on the frame rail?
Old 03-15-2010, 10:52 AM
2x6 bulldog's Avatar
2x6 bulldog
2x6 bulldog is offline
Both filters are in the kit. Frame rail and engine mounted.
Old 03-15-2010, 11:16 AM
freekyFX4's Avatar
freekyFX4
Thanks. I am about to turn over 15k miles and need to order the filters.
Old 04-01-2010, 09:19 PM
Gearitis's Avatar
Gearitis
Gearitis is offline
Could not find where the updated Fuel Filter number was posted so I am doing an update here. FD-4617 are the updated fuel filters for the 6.4L. Yes, from what I am seeing, the O-ring is the difference and they seem just a little more dense.
Old 04-02-2010, 06:24 AM
jrc55's Avatar
jrc55
jrc55 is offline
They are taller as well so the o-ring will slip inside the housing.
Any of you that change your own fuel filters ever take a light and look inside the primary housing? I found crud on the bottom of both of mine and even some further up inside where the new style o-ring goes in. Tough to clean out.
Old 04-02-2010, 07:11 AM
Gearitis's Avatar
Gearitis
Gearitis is offline
What was your solution to getting to the crud and cleaning it out?
Old 04-02-2010, 02:27 PM
jrc55's Avatar
jrc55
jrc55 is offline
Long skinny screwdriver to reach up in the o-ring area, pulling, raking or whatever to the bottom of the housing and wiping till the white towel came out clean. Real pain in the ****. One was dirtier than the other so cycled the pump and drained it again but the container that caught the fuel was clean. Hopefully I didn't stir up a mess, both trucks have been running fine.
Old 09-25-2010, 02:06 PM
bnmccoy's Avatar
bnmccoy
bnmccoy is offline
Worthy of bumping this post as some places may try to sell you the old fuel filters FD-4609; you now want the FD-4617 for the 6.4 diesel F-series trucks.
The filter sets for the 6.0 were updated too: FD-4604 is replaced by FD-4616.
I have read that the new 0-ring on the end of the filter opposite the cap was to prevent water from getting pushed past the filter in some cases; elsewhere on this site I have read it was to prevent crud from getting past the filter. In any case I don't think any of us want anything getting past the filter w/o passing through it.
I missed this original thread and some similiar to it and only became aware of the new filters when noticing a difference on son-in-laws fuel filters for his 6.0 PSD. So hopefully bumping this thread might help someone else out there.....
Bob
Quick Reply: updated fuel filters
