valve timing
Old Oct 29, 2009 | 05:47 PM
keg's Avatar
keg
valve timing
can anyone help
motor is being rebuilt and i need help with the new timing gear I have a procomp timing cam gear drive does any one know what position the cam gog should be as it has 9 possibles I assume the crank is set with the mark at 12 oclock position
Old Oct 29, 2009 | 07:51 PM
75F350's Avatar
75F350
Welcome to the site:
In this case, it is tough to answer this question since we know not what you are working on.
Some performance engines and some cams require a different cam timing than others. Many factory set ups use a rather retarded timing, and it helps to advance a bit.
Straigh up or zero is a good basline for most applications.
You should refer to your instructions to determine which position will provide you with the desired cam timing.
