brake light wiring
Old Oct 29, 2009 | 04:42 PM
edwardo's Avatar
edwardo
brake light wiring
The brake lights stopped working on my truck.I checked for power at the switch on the pedal and one side has 12volts and the other has 8volts even when the switch has been unplugged.Must be a short somewhere,any ideas???
Old Oct 29, 2009 | 04:50 PM
wolfsmurf's Avatar
wolfsmurf
i always check the trailer lighting plugs when talking about brakes or taillights. alot off times there is corrosion in the connections.
Old Oct 29, 2009 | 07:07 PM
edwardo's Avatar
edwardo
well after laying on my back for most of the day the lights are working again!!
I found a red with yellow stripe wire under the dash that was broken,someone had used a connector on it before that cut its way through the wire.I have no idea what the wire does but don't really care as long as the problem does not come back.
fordf348
Jul 29, 2014 07:08 PM
Rob Cuenin
59
Apr 1, 2013 04:21 PM
goompus68
Jul 7, 2011 02:54 PM
John with beastly 302
Dec 1, 2007 09:49 AM
doug51f1
22
Dec 17, 2006 04:20 PM
