Sponsored by: Real Truck
Broken Oil Pipe... HELP
Old Oct 29, 2009 | 02:59 PM
RCM's Avatar
RCM
Now what do I do?
2005 F350 - Never again buy an after market filter!!!!
I could use some help on what to do to fix this and how to find the missing broken piece.
Thanks
DumA$$
Old Oct 29, 2009 | 06:48 PM
F350-6's Avatar
F350-6
Ask down in the 6.0 section. If you're wanting to save money on filters, get them from International. As you've learned, avoid the "will fit" stuff.
Old Oct 30, 2009 | 07:32 AM
benbishop's Avatar
benbishop
Yeah there are also 2 filters available at the parts stores for the 6.0s. There is usually a sheet in the box with the filter describing which to use. If you have an external spring on the shaft in the housing you need to use the filter with attached screw on cap. If you just have the plastic spiral on the center shaft in the housing you need the separate filter, and to reuse your screw on cap.
Old Oct 30, 2009 | 07:36 AM
RCM's Avatar
RCM
Old Oct 30, 2009 | 08:30 AM
Sarge261's Avatar
Sarge261
As far as I know there is only 1 filter to use in a 6.0 Motor Craft does not offer more than 1 filter part number for the 6.0 years 2003-2007. If your parts place offers 2 numbers run to the closest walmart and buy a fram or motorcarft, or you will have the same issues as the OP.
To the OP I think you can buy the housing, but you would have to contact a Ford or I/H dealer to get that answer. Maybe conatct Ed at Y2k Ford parts hes awesome to deal with and will get you hooked right up. Tell him your from FTE.
Good Luck,
Sarge
Old Oct 30, 2009 | 08:45 AM
benbishop's Avatar
benbishop
That's interesting. Advance, Carquest, and Napa all have 2 different filters listed, based on which housing the truck has. At least for 04s.
Old Oct 30, 2009 | 08:51 AM
Sarge261's Avatar
Sarge261
I dont think the housing cghanged at all. I think what they are selling is a universal or will fit filter that comes with a filter cap...not good. Then they sell a filter that works with the stock cap. I would stick with a MC, Fram, I/H, or anyother of the Racor branded filters.
I will always spend the extra $$ for the right filter than end up with problems, possibly a lot worse than what the op has.
Just my .02
Sarge
