Powertrax Lockers?
Old Oct 28, 2009 | 11:44 PM
thekingofcows's Avatar
thekingofcows
Powertrax Lockers?
Has any one tried powertrax no-slip lockers? They seem like something to be skeptical of since there a good bit cheaper. How do you think they would hold up to very large tires, and a big block in the mud, and hills. (no rocks).
Powertrax No-Slip Locker Traction System
Old Oct 29, 2009 | 01:22 AM
75F350's Avatar
75F350
Lunch box lockers utilize the stock open carrier and use the stock pinion gear cross pin. These are weak links and break often. Large tires will bring an end to the lunchbox locker. A full carrier locker is best and well worth the extra money. Cant go wrong with a Detroit...........
Old Oct 29, 2009 | 01:25 AM
CrazyAirman's Avatar
CrazyAirman
Been running a powertrax in my 9 inch for 5 trouble free years.
Old Oct 29, 2009 | 01:33 AM
MotherTruckinMarine's Avatar
MotherTruckinMarine
These are what is referred to as a "lunch box locker". It is a locker(similar to a lock-right) that only replaces the spider gears in an open differential. Now as far as lunch box lockers go, powertrax is the smoother of the other brands out there. However, these lockers do not add any strength to your diff because you are using the stock carrier. They are pretty easy to install with no special tools. You do not have to remove the carrier, just the spider gears. It is highly recommended to upgrade your carrier center pin when you install a lunch box too. As for standing up to large tires and big HP, spend the money on a Detroit. They wont stand up to anything larger than 33" tires under moderate abuse and nominal power. Not the best choice for a full sized truck with anything larger than 31" tires. They will work with larger tires, but nothing to rely on. Hope this helps.
Old Oct 29, 2009 | 11:34 AM
thekingofcows
So not a particularly good choice for the front end then. that is good to know. thanks.
Old Nov 1, 2009 | 03:39 PM
MotherTruckinMarine
actually, I would put one in the front before the rear so long as its not getting the hell beat out of it
03-F150
1997 - 2003 F150
May 1, 2015 11:32 PM
351Cleveland C4
27
Aug 1, 2014 03:16 PM
ekuhn
1983 - 2012 Ranger & B-Series
Dec 25, 2010 09:58 AM
BootHill
1978 - 1996 Big Bronco
Jan 18, 2005 09:30 AM
