is there a link or step by step
Old Oct 28, 2009 | 03:06 PM
TheWingnut's Avatar
TheWingnut
on how to replace the rear shocks on a 83 F-250 4x4 I-6 4.9L 300?
wingnut
Old Oct 28, 2009 | 03:23 PM
andym's Avatar
andym
Unbolt old shocks. Bolt in new shocks.
Seriously, that's about all there is to it.
Old Oct 28, 2009 | 03:27 PM
TheWingnut's Avatar
TheWingnut
Do I have to jack up the rear end and put it on Jack Stands?
Old Oct 28, 2009 | 03:42 PM
rmalottwtes30's Avatar
rmalottwtes30
No just take off the old ones and replace with new ones.
Old Oct 28, 2009 | 03:44 PM
TheWingnut's Avatar
TheWingnut
cool thanks
Old Oct 28, 2009 | 05:01 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Nitrogen filled shocks take a little extra effort because they want to extend themselves. They usually come with a wire on them so they stay compressed. For nitrogen filled front shocks I bolt the bottom mount first then cut the wire and let the bolt on the top of the shock shoot through the mounting hole. The mounting bolts on nitrogen filled rear shocks are usually both horizontally aligned. So I bolt the top mount first and then it's easier to hold onto the bottom part of the shock to compress it while I line up the bolt to the bottom mount.
Old Oct 28, 2009 | 06:14 PM
bashby's Avatar
bashby
And to add to that, if you let them extend all the way they kinda stick there and can be a little tough to compress
