Engine Help
Old Oct 27, 2009 | 10:22 PM
countrykid_86's Avatar
countrykid_86
Engine Help
I have had a noise that seems to be coming from under the left valve cover. The noise started a couple months ago and has been getting progressively worse. It is a clatter/shatter type noise and is worse when the vehicle is cold or at lower RPM. I hooked it up to an AE scanner and got cylinder failures on #2 and #8. I concluded that one of these injectors must be going bad. I got two new remanufactured injectors and i just finished installing them. Just got back from driving it and the noise is obviously worse than before. I know that it will run funny until i get the air out the system, but this is still the same noise, only louder. I am really stumped and frustrated, does anyone have any ideas for me?
Is their ever an issue with injector timing?
If it is one of the other injectors, how do i diagnose it?
Old Oct 27, 2009 | 11:41 PM
TERSEJR's Avatar
TERSEJR
Did you get any other codes like IDM faults or anything when you scanned it?
If you can, test the compression of the cylinders.
Old Oct 28, 2009 | 07:40 AM
countrykid_86
It didn't pop any codes and it passed the buzz test. It had pretty high rotational velocity on cylinders #3 and #8, like a little over 3 was an average reading. Been thinking about it tonight, and since the noise is worse it must be because i changed out one of the wrong injectors and either 4 or 6 is faulty and the air in the system makes the noise louder. Otherwise the problem is not with the injectors and i have bigger issues like bent rods or worse. I did hydro-lock it slightly last night, i didnt crank on it a bunch, it locked up right away and i stopped and jerked everything back out and then cranked it a while and got all of the fuel/oil out of the cylinders. After that everything was fine, but what if i had a bent rod and i tweeked it a little more. I am just brainstorming, i don't want ot have to take it somewhere, especially not the dealer. The frustrating part is that it runs, it just sounds like **** and diagnosing it is a b***. Thanks for any help ahead of time guys!!
Old Oct 28, 2009 | 09:01 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Have you changed the CPS lately? Seems the gray one will mess with the #3 and #8 injector codes on a few trucks. Did you check all the hold down bolts and rocker bolts?
Old Oct 28, 2009 | 09:10 AM
countrykid_86
I have a grey CPS, I went in for the recall right after I bought the truck a couple years ago, I have regretted that mistake ever since. I ordered another grey one and changed them out about three months ago. Sure wish I could find an old black one!! I had already checked and re-torqued everything under the valve covers, I was hoping for a simple fix, at first.
ddeflyer
20
Feb 13, 2015 08:29 AM
1978fordf250
Jun 24, 2006 11:32 AM
hink10
18
Apr 18, 2006 11:29 PM
bigric
Aug 29, 2003 10:01 AM
