Modular V10 (6.8l)
99 V-10 O/D button
Old Oct 27, 2009 | 04:30 PM
MXZX1100cc's Avatar
MXZX1100cc
99 V-10 O/D button
Well I have a 99 with 113,xxx miles on the truck other day i was pulling a 20ft. trailer and it a had a bobcat on it. I rented the bobcat and trailer so first time pulling it. I was going down the highway and came to a hill and it shifted out of o/d so i hit the o/d button to turn it off. Well i got to my house and unhooked the trailer and took back off I pushed the o/d button to turn it back on and nothing? It almost seams like the button is stuck? Have you guys ever heard of this before. Thanks
Old Oct 27, 2009 | 05:08 PM
dkf's Avatar
dkf
Sometimes wires can break in the column going to the OD button. The OD button itself can also just wear out and/or the light can burn out.
Old Oct 27, 2009 | 06:09 PM
dew the thunder's Avatar
dew the thunder
Well the nice thing is that you'll have overdrive back after you shut down and restart as I'm sure you already found out.
Sometimes you can get lucky if the wires are broke by wiggling the shifter handle while pressing the button.
Replacing the whole shifter assembly with a new one (the shifter, boot, button, and light) is only around 40 bucks and will take up 15 mins of your time.
Old Oct 28, 2009 | 08:32 AM
MXZX1100cc's Avatar
MXZX1100cc
Well I have turned off and started back up I dont no how many times and the od never came back on, and the little light is still on also that says off?
Old Oct 28, 2009 | 01:14 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
definitely sounds like the wires broke.
Old Oct 28, 2009 | 03:40 PM
MXZX1100cc's Avatar
MXZX1100cc
Well thanks guys I was prepairing for the worst and this is deffently better than what I was planning. And another ? is how you go about chainging the gear selector cant be to bad if it only takes 15 mins. Thanks!
Old Oct 29, 2009 | 07:22 PM
saggys's Avatar
saggys
I would check for broken wires in the column. I fixed mine this summer, its not too bad of a job.
