Hard Start diesel
Old Oct 27, 2009 | 02:56 PM
garyh8's Avatar
garyh8
Hard Start diesel
1993 7.3l glow plug relay cycles about every 3 seconds. ngine will not start unless very arm weher or engine block heater lgged in.
Thanks
Old Oct 27, 2009 | 03:30 PM
Lazy K's Avatar
Lazy K
I bet you have some bad glowplugs. You can test each one or just throw in a complete new set. Only use Motorcraft/Beru plugs.
Old Oct 27, 2009 | 03:53 PM
Fordranchero's Avatar
Fordranchero
Glow plugs
Be absolutely sure it's not the relay gone bad.
I've twice had this happen when the plugs were not bad.
Old Oct 28, 2009 | 09:55 AM
garyh8's Avatar
garyh8
Hard start Diesel
Thanks for the info. I found a broken battery cable on the driver side battery and after repair the engine spins fast enough to fire up.
I still have the glow plug relay clicking every 1 second for aproximately 15 seconds and then stops so I fear getting stranded with an unknown.
I plan to check all the glow plugs to see if there is a problem there.
Old Oct 28, 2009 | 10:24 AM
Fordranchero
Relay
It is normal for it to cycle on and off until the engine warms a bit, that's how it is supposed to work.
Unless it is still not firing up from cold, I would say it is working.
Old Oct 28, 2009 | 10:33 AM
tjc transport's Avatar
tjc transport
i ain't rite
proper glow plug opperation with a cold engine is key on, the wait to start light should stay on for 15 seconds or so, then you will hear a click from under the hood for another 15-20 seconds.
