any one know where i can get a case/bell housing for a c6, i need a new one and would like to see if i cant get one for cheap before i take my truck to the transmision shop.
o well already took it, finally ill be able to turn my truck off without being scared of hearing the sound of the starter just spinning and teeth of the flywheel being broken off when i need to turn it back on!!!
Mike, I am a little slow here, What does a tranny case have to do with the starter? Is it busted so the starter isn't inguaging correctly?
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
yeah, when my sister owned my truck (before i lifted it and did all the mods to it) she had a new starter put in it. well the people that put it in used an impact wrench to tighten down the bolts and it striped out the threads of the case:-X23 . they redrilled the hole and welded a bolt to the other side so that they could put a starter on it. but because they hole was bigger than usual the starter could now push itself away from the flywheel after about 6-8 starts, wearing teeth down on the starter and the flywheel. because of that my flywheel has a whole little section of teeth missing and my truck always seems to stall on that part when im out on the trails, not fun.
got the truck back and it wont start cause it needs a new nuetral safety switch. only reason i say this is because no one would happen to have one lyin around would they???
