Ontario Chapter Join Chapter>, Leader: loudfords
'94 7.3 NA 4wd CC, barely running...
Old 10-26-2009, 08:55 PM
prisoner of gravity's Avatar
prisoner of gravity
prisoner of gravity is offline
hi guys, the truck in the subject line followed me home. 330,000 km on it but body is excellent by southern Ontario standards. Starts easily but LOTS of white smoke and after a minute or two it dies. Seems like it is being overfueled??? Where do I start? Replace injectors? Replace IP? Both? I have no service history on this truck but injectors and lines do not look like they have been disturbed this decade.
Any recommendations on a reliable source for injectors and IP in southern Ontario? Nothing fancy, just stock spec and hopefully from a source I can trust. I'm near Peterborough.
This truck deserves a second chance...
Old 10-29-2009, 10:31 AM
fp_5's Avatar
fp_5
fp_5 is offline
No responses? I can't help you with diesel issues but I was hoping to learn something.
Try the diesel forums and let us know how you make out.
Frank
Old 10-29-2009, 06:29 PM
Red Ford Truck's Avatar
Red Ford Truck
Red Ford Truck is offline
Take it into Moynes in Lindsey.
I would suggest you take it into Moynes in Lindsey(great folks to deal with), and they specialize in Ford Trucks.
Get them to pull the codes before you start changing things, it could end up being something simple, or you may be able to just pick their brains for some advice.
Or hit the diesel forum as Frank suggests.
Either way good luck.
Rick.
Old 11-03-2009, 06:51 AM
triskadek's Avatar
triskadek
triskadek is offline
Hi, I only just moved to Ottawa. I have a '97 TDI, and it does sound like its too much fuel, or maybe the air filter is just that extremely clogged?
I would definitely post to your forum with the symptoms.
As for parts, I'm only just learning the Ottawa area. All I can say so far is thank goodness for NAPA, and thank goodness I haven't needed more than a starter and GPR.
Good luck, and keep in touch in the chapter.
Old 11-03-2009, 06:52 AM
triskadek's Avatar
triskadek
Oh, does the '94 even have ODB I ? I don't recall seeing any interfaces on my buddy's back in SoCal multiple IDIs.
Old 11-03-2009, 11:44 AM
triskadek's Avatar
triskadek
I don't think the IDI's were brained, so no ODB
PStruwing
08-01-2011 07:54 PM
NiTeRiDeR
Ontario Chapter
05-27-2009 11:53 AM
prisoner of gravity
Ontario Chapter
03-22-2009 10:58 PM
voltson
Ontario Chapter
16
04-27-2007 07:36 PM
Quick Reply: '94 7.3 NA 4wd CC, barely running...
