Funky Electrical BS (all my lights are goofy)
So since I had bought the truck the low beam headlights did not work. Neither work at all BUT the high beams do. I took the bulbs out to inspect and both filiments looks superb. I checked (what I believe to be) all fuses and they are peachy. Now today BOTH my turn signals take a **** on the porch.
I'm leaning towards the turn signal switch that handles the wipers, high/low beam, and turning. Do you agree?
My hazard lights work too...
Thanks!
Beefey
Thanks!
Beefey
A loose connector (not completely seperated) can still allow some functions of the switch.
Also, a bad switch can have some functions operable and others not.
(not to split hairs,technically it is a multi-function switch,not a t/s switch)
Just curious,do your brake lights work?
I'll also throw out one more thing,check the terminals at the headlight plugs for B+ at the low beam pins.
I ordered a haynes manual but just pulling off the column cover it looks like it's gonna be a REAL bear getting that thing out. There are no visable screws fixing it to the column so I'd imagine they are under the steel part of the column, I'll take a picture tomorrow.
Thanks!
Beefey
Thanks!
Beefey
The switch won't take more than 5 min. to get out.
Turn the key to "on",release the ign.cyl.
remove the cover screws,remove the tilt lever if equipped.
The multi function switch is right there !
Update:
I changed out the switch with no resolve... The turn signals are still inopperable... So this is what was checked and tested to be good:
1. Console Multi-Switch (replaced)
2. Fuses (all good)
3. Bulbs (good)
Only idea's I have left:
1. Turn signal relay (neither signals work)
2. some fried wiring...
Ok so Haynes says there is a turn signal relay somewhere in the loop, can anyone verify this and it's location? I think I'm gonna take a stab at this next and if this isnt it I'm SOL. Anything I left out?
-Thanks
Beefey
2. Fuses (all good)
3. Bulbs (good)
-Thanks
Beefey
