2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
how to remove factory radio in an 08 limited
Old 10-09-2008, 09:43 PM
almbon's Avatar
almbon
almbon is offline
I want to wire in my Sirius Starmate so it turns off when the accessories go off. I tried to wire it from the fuse box thinking it was just like my Stang...it's not, who knows how the dash comes apart and what wire do I tap in the radio's loom for that, Also will the Ford satellite antenna work with my aftermarket unit.
If anybody has a schematic that would awesome
Old 10-10-2008, 10:31 AM
berry1234's Avatar
berry1234
berry1234 is offline
Email me and I can send you the .pdf. It just pulls off. bmwolfe at yahoo dot com.
Old 10-10-2008, 07:42 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
Search stereo access, you will see that I wrote a how to including pics to take the console apart.
Old 10-10-2008, 07:44 PM
almbon's Avatar
almbon
almbon is offline
thanks I'll look
Old 10-11-2008, 05:24 AM
nfntruth's Avatar
nfntruth
nfntruth is offline
I also have another post where I talk about wiring up an aux outlet through a switched circuit in the fuse box. That may be easier than actually removing the stereo.
Old 10-30-2008, 10:50 AM
rbarbot2's Avatar
rbarbot2
rbarbot2 is offline
I can't locate the post about taking the CONSOLE apart. I searched Stereo Access but it doesn't come up.
I have something rolling around underneath my shifter, sounds like a BB. I found one screw under the forward rubber tray but don't know how to release the console.
Old 10-30-2008, 11:06 AM
berry1234's Avatar
berry1234
PM me and I can see if I have the PDF to take that apart.
Old 10-30-2008, 02:33 PM
nfntruth's Avatar
nfntruth
nfntruth is offline
Old 10-26-2009, 11:42 PM
david_jr's Avatar
david_jr
david_jr is offline
Forgive my ignorance. Am I doing something wrong? I don't see the links or photos. Could it be a browser setting?
Old 10-27-2009, 12:11 AM
Tylus's Avatar
Tylus
Tylus is online now
MMNC (SS)(Ret)
1. turn your key to the run position but leave motor off
2. shift into 1st gear
3. grab the bottom trim panel beneath the A/C controls and remove
4. grab the bottom of the radio surround trim panel and pull out
5. unbolt the radio and pull straight out
6. unplug the wiring connections when accessible
here is a video of the dash demolition for you
EXPEDITION INSTALL
Old 10-27-2009, 12:37 AM
david_jr's Avatar
david_jr
david_jr is offline
EXPEDITION INSTALL
Thanks so much!! Doing an XM direct adapter this week. That video is awesome.
Ryan Cooper
13
04-04-2017 10:25 AM
J ballan
1999 to 2016 Super Duty
01-30-2017 03:17 PM
Jterr
01-08-2017 03:53 PM
Vaokie1
08-23-2010 06:58 PM
Shepard
07-14-2006 07:56 PM
Quick Reply: how to remove factory radio in an 08 limited
