t-stat housing
Old Oct 24, 2009 | 11:45 PM
jan whipple's Avatar
jan whipple
t-stat housing
hey guys i have a water pump change out in my near furture. i saw a link here a while back on a billet t-stat housing can't find it now can anyone help thanks
Old Oct 25, 2009 | 12:27 AM
hucka1a's Avatar
hucka1a
Here ya go. http://www.dieselsite.com/index.asp?...ROD&ProdID=188
Old Oct 25, 2009 | 07:26 AM
riverrat41's Avatar
riverrat41
Welcome to FTE....Huck has you fixedn up!!!!
Old Oct 25, 2009 | 07:42 AM
big poppa's Avatar
big poppa
Just FYI, if you have the upper rad hose that goes thru the belt, after installing this billet housing, trim an inch or so off the hose. The billet housing is thicker than the stamped steel one and when the hose swells it hits the ALT. underside bracket, eventually it will rub a hole there..
Old Oct 25, 2009 | 07:54 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
I'm going to "one-up" you Mike and since he's looking at putting in a new water pump, now is the perfect time to replace that hose with one that goes around the serpentine belt. NAPA sells it for $50(ish) and with the "new" hose you'll be able to change your serpentine belt without having to disconnect that hose.
Old Oct 25, 2009 | 08:00 AM
big poppa's Avatar
big poppa
You can "One up" any time you want there Brandon, thats what makes FTE a great place My hose was still ok so I went with it but i'm going with around the belt when its time, thats for sure..
Old Oct 25, 2009 | 08:31 AM
WA.Ranger's Avatar
WA.Ranger
You can get a Gates 22433 for less than that at O'Rileys.
While we find your parts, please enter your ZIP Code at CSK Auto
Old Oct 25, 2009 | 08:41 AM
papadelogan
who's Brandon?
Old Oct 25, 2009 | 09:04 AM
Ponyboychris's Avatar
Ponyboychris
Hey Brandon... j/k!!!
Napa part #NBH9066 "Preferred Hose Routes Around Serpentine Belt" = $14.99.
Very good time to replace that hose if the T-stat housing is being swapped out.
Old Oct 25, 2009 | 11:01 AM
jan whipple
thanks for that link guys and the tip i got the hose that goes around the belt thank again guys
Old Oct 25, 2009 | 11:34 AM
hucka1a's Avatar
hucka1a
GATES Part # 22433 More Info {Molded Coolant Hose; 1 23/32" x 25" Does Not Contain Spring}
Upper; Preferred Hose; Routes around serpentine belt.
Rock auto $8.11
Old Oct 25, 2009 | 04:01 PM
big poppa's Avatar
big poppa
who's Brandon?
Sorry dude, I'm known for these blips, ask Jason or Justin..
