power steering
Old Oct 24, 2009 | 09:23 PM
cervantes's Avatar
cervantes
power steering
my 71 f100 has power steering,it works good most of the time and then all of a sudden it gets hard to turn,also the dip stick states to use transmission fluid,i used power steering fluid before i found out about the trans fluid,could that be the problem
Old Oct 25, 2009 | 06:59 AM
jowilker's Avatar
jowilker
You are OK using power steering fluid. I think the tranny fluid was cheeper.
You prolly have a Bendix gear and they were problematic. Ford soon changed to the Saginaw pump, that is mucho better.
John
Old Oct 25, 2009 | 09:39 AM
cervantes's Avatar
cervantes
okay, thank you so do you think the power steering is going bad
