Sponsored by: Real Truck
2002 headlights
Old Oct 24, 2009 | 08:16 AM
pkenn7's Avatar
pkenn7
2002 headlights
will 2004 headlights fit on a 2002? do they have to be retro fitted?
Old Oct 24, 2009 | 09:53 AM
F350-6's Avatar
F350-6
2004 should work fine. 05 is when they changed to the style & shape.
Old Oct 24, 2009 | 12:31 PM
ameinig's Avatar
ameinig
I swapped to 2004 lights and markers on my 1999. Worked just fine.
Old Oct 26, 2009 | 02:06 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
Can the lights off of the 05 and up be fitted to the earlier trucks? My brother in law wants to update his 01.
Old Oct 26, 2009 | 03:57 PM
T8R's Avatar
T8R
Yes, they'll fit. There are several other threads on this. I believe you need the adjusting screws from the newer lights as well as having to trim the header panel. (the sheet metal panel that the lights bolt to) I haven't tried it yet, but from what I hear it isn't difficult if you're handy with tools. You can also choose between the standard chrome and the black HD edition, depending on the look you're going for.
They're available at RiffRaff and Clay's customer service is top notch.
Riffraff Diesel: 05' Ford OEM Headlights
Old Oct 26, 2009 | 04:42 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
On the 2005 conversion you will need to trim your header panel, but besides that you are good since the adjusters on the 05' headlights are in the assembly.
Old Oct 26, 2009 | 07:14 PM
F350-6's Avatar
F350-6
That and you have to do something to the wiring since the plug for the older headlights won't work with the 05's. Looks like Clay has those available. You just need to know something is needed before you do the swap.
chartkor
Escape & Escape Hybrid
Jun 3, 2016 11:58 PM
rvdealer
1997 - 2003 F150
Sep 19, 2007 12:03 PM
boyadam1
Jun 27, 2003 03:58 PM
mbnv992
Sep 17, 2002 07:40 PM
tobyk
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jan 7, 2002 05:28 AM
