Performance Battery?
Old Dec 8, 2009 | 10:56 PM
verotik66's Avatar
verotik66
i've got the perfect Ex for those speaker parts, send them right over! lol
Old Dec 9, 2009 | 07:14 AM
AltaEx's Avatar
AltaEx
Originally Posted by verotik66
was unable to start my ex on several cold cold days last winter, don't want to be there again this year, so I am replacing the 5yr old battery with something with a little more CCA found in these batteries. I am paying alot more yes, but possibly will see several years more use out of a set of batteries... Will this equal out? probably not, peace of mind at -40c possibly!
I've got the same problem. -25, snow in the forecast, my car's driver's side wiper arm just failed (now that's a critical failure!), so go to grab the truck and the battery is too far drained to start it, the truck having sat unused for two months so have it on the chrager right now. (New battery from the dealer last spring.)
I'm again thinking of a battery like this, dual batteries with an isolator or solar charger or some solution. I can't have a new battery draining completely and freezing. Thought this was interesting...
"Hawker Energy has for numerous years been building such batteries for the military and has recently gone through a $9 million expansion so it now can offer this military-spec battery to the public. Labeled under the name Odyssey Dry Cell, it's classified as both a high-pulse-rate discharge (for engine cranking) and a 100-percent depth deep-discharge battery. What this breaks down to is that you're getting two batteries in one,"
..."Note three features of the battery post: First, it's made of brass. Second, the area intended for the battery cable clamp is knurled for positive contact. And third, the center is drilled and tapped for a 3/8-inch bolt as an accessory mount." source: Willie Worthy, Hawker Energy Products Odyssey Battery PC1700 - A New Top Gun In Town?, Hawker Energy's Odyssey Battery, Fourwheeler.com
Hawker Energy Products Odyssey Battery PC1700 - Four Wheeler Magazine
Old Dec 9, 2009 | 08:59 AM
desertt5's Avatar
desertt5
Am I the only one running good ole International batteries?
Old Dec 9, 2009 | 03:50 PM
EXv10's Avatar
EXv10
I think HYPE has leaked into the battery market like everything else. My Walmart battery does everything you could want it to (supply juice!) and does it for a long time.
Old Dec 9, 2009 | 03:56 PM
HD RULES's Avatar
HD RULES
Agreed and at $75, does it just fine.
Old Dec 10, 2009 | 06:55 PM
AltaEx's Avatar
AltaEx
I'm not so sure about that...
"Issued: 4.00 PM MST Thursday 10 December 2009
Tonight:Cloudy. A few flurries beginning early this evening...
Saturday:Cloudy with 60 percent chance of flurries. High minus 26. Sunday:Sunny. Low minus 34. High minus 30.
Monday:Sunny. Low minus 35. High minus 25."
Old Jul 28, 2010 | 11:34 AM
verotik66's Avatar
verotik66
Well i bit the bullet and put in two new Odyssey Battery PC1750's in the excursion.
Bubba Hines
Dec 19, 2015 09:06 PM
rufushusky
Sep 21, 2015 08:14 PM
Thomas White
Jul 11, 2015 01:25 PM
idiabuse
Dec 7, 2014 12:36 PM
JIMRSX
Apr 5, 2008 02:16 PM
