Need wiring diagram
Old Oct 23, 2009 | 01:53 PM
jswisc's Avatar
jswisc
Need wiring diagram
I picked up two doors from an 89' F250 and they have power windows and locks. They're going on my 87' that is all manual. I need the wiring diagram for the power windows and locks. My Chilton shows the diagram only for the 92'-96' years and the wiring set-up doesn't match the wire colors. Any help will be appreciated.
Old Oct 23, 2009 | 03:33 PM
g_k50's Avatar
g_k50
You might try to find one over in the Full Size Bronco section. There's a lot of Eddie Baur's that have power windows.
My 1990 Bronco Service Manual shows power for the door locks comming out of fuse 12, 30A. Black with a white stripe. Goes to terminal A on the door lock switch
https://www.ford-trucks.com/forums/p...ictureid=18895
https://www.ford-trucks.com/forums/p...ictureid=18894
The Power Windows get their power from Fuse 14, 20A the wire is red with light blue stripe, go into a connection c719 and comes out in a light green with yellow stripe wire.
Old Oct 23, 2009 | 03:43 PM
danr1's Avatar
danr1
If you need more let us know, 87 and 89 are both covered in the same sub section of the book, as in the wiring is the same.
Old Oct 23, 2009 | 03:50 PM
danr1's Avatar
danr1
Huh? oh well, there was no other response posted when I started scanning and uploading! lol
Old Oct 24, 2009 | 05:32 AM
jswisc's Avatar
jswisc
Thanks for the diagram.
Old Oct 24, 2009 | 09:26 AM
subford's Avatar
subford
Happens to me all the time. But the other do not post Images with their posts.
