Sponsored by: Real Truck
Adding spacers to a 4x2
Old Oct 22, 2009 | 05:29 PM
TexasRebel's Avatar
TexasRebel
The way I've figure it out, different configurations have different spacers between the springs and axles.
4x2 f250 = no spacer
4x4 f250 = 2" spacer on rear ? on front
4x4 SRW f350 = 4" spacer on rear ? on front
4x2 SRW f350 = ?? on rear
anyway, long story short...
My B&W turnoverball runs the risk of tapping the differential housing when the ball is upside down and I'm loaded (or hit a large bump too fast). According to the B&W literature, this is only a problem on the 4x2. The way I see it, this is because of the absense of the spacer.
What would happen if I were to simply add 2" spacers to the rear of my 4x2? How much would that require I change my front alignment if at all?
2" over 137" = 0d 50m 11s
Old Oct 22, 2009 | 09:07 PM
Lubbockguy1979's Avatar
Lubbockguy1979
if you raise the rear only it shouldnt play a big role on the front suspension other than loading it with a slight weight shift forward. i would assume that you could do f250 4x4 block in the rear and 2" spacers on the coils up front and get a all around lift. then you might need to have the alignment checked
Old Oct 22, 2009 | 09:40 PM
seminaryranger's Avatar
seminaryranger
If you add the F250 4x4 lift block (spacer) you'd probably get a pretty good rake going on when you're unloaded. This is what the rear suspension looks like on my '09 (although it's flexed out crossing a berm). Notice the spacer.
You might consider leveling out the front, because I forsee the rear block, by itself, putting the back of the truck too high for an unloaded condition. The front allignment shouldn't change if all you do is lift the back. My $.02
Good luck!
Old Oct 22, 2009 | 10:00 PM
FireMe's Avatar
FireMe
As you noted, you'll lose almost a degree of caster. Depending on your current alignment, this may or may not be noticeable. Loaded, the blocks will probably put you back close to your previously unloaded specs.
Personally, I don't think adding the blocks would be a bad deal overall.
You could probably throw a jack under your hitch with some blocking and use a tape measure to jack the rear end up two inches, then see how it would look while unloaded and see if you would be satisfied with the way it looks or not.
Jay
Old Oct 23, 2009 | 12:51 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
These are the threads I remember on block swaps. Parts #s are pre 08, but the info and install is the same. And this would be a great excuse to put caster shims into the front end, and tighten up your steering in general. Those shouldn't be too hard to put in, and from what I hear really help out. I'm doing the 4" block swap/ 2" front with shims on my 250 here pretty soon.
https://www.ford-trucks.com/forums/7...lock-swap.html
https://www.ford-trucks.com/forums/6...ar-blocks.html
Old Oct 23, 2009 | 04:31 PM
jonrjen's Avatar
jonrjen
The easiest way to correct the ball from hitting the housing would be to simply...take the turnover ball out and store it in the truck.
I don't leave my ball in the hitch unless I am going to be using it. When you consider how easy it is for someone to steal your turnover ball and the price to purchase a replacement, it just makes sense to not tempt anyones honesty.
Old Oct 23, 2009 | 06:07 PM
TexasRebel's Avatar
TexasRebel
I don't want to leave the slot empty, nor do I want anti-seize in my cab.
I have NEVER heard of somebody losing a gooseneck hitch to theft and will play the odds on that one.
With the type of anti-seize I use, I hope the theif likes grey...ON EVERYTHING.
Caster shims? do you have a 4x2 or a 4x4? How exactly would caster shims work on a Twin I Beam?
Old Oct 23, 2009 | 06:12 PM
TexasRebel's Avatar
TexasRebel
it got me curious, and I just went and looked...
There are two sets of holes to connect the leg of the beams... the beams are also not one piece anymore!... mine are connected to the higher & shorter hole, there is another hole that is about 1/2" lower and 2" back.
Does an F350 4x2 use longer legs on the beams?
Old Oct 23, 2009 | 11:45 PM
texastech_diesel
Token Redneck
My bad, I dunno what I was thinking on that one, I just skipped over the 4X2 deal.
I'm going to the game tomorrow, Wreck 'Em!
Old Oct 24, 2009 | 03:00 AM
TexasRebel's Avatar
TexasRebel
Gig 'Em
At the game last year in Kyle, a female friend of mine witnessed some of the Raiders we were sitting with put their guns up after ya'll scored...
she turned to me and said, "what are they pointing at?"
