53 cab mounting
Old Oct 21, 2009 | 02:55 PM
austin2466's Avatar
austin2466
53 cab mounting
Are the stock rear cab mounting arms on my 53 f100 adjustable? It leans a little to the left and was hoping for a cheap fix.
Old Oct 21, 2009 | 04:55 PM
jvmcc's Avatar
jvmcc
The arms on which the cab is bolted have rubber bushings, but no adjustment that I know of. If the problem isn't a rotten rubber bushing, then it might be that the arm is cracked and bending down a bit. That happened to my 53. I put it on a new frame. I regret doing that, now. When I tossed the old frame, I also tossed out the VIN number.
Old Oct 21, 2009 | 06:56 PM
jaye's Avatar
jaye
Mine was also leaning to one side the frame was bent.
Old Oct 21, 2009 | 07:08 PM
56panelford's Avatar
56panelford
You can buy adjustable ones from Midfifty but I believe they're fairly pricey. It's likely a rotton rubber or bushing that you could also buy as a kit http://www.parts123.com/PartFrame.as...ty_F-100_Parts
Click on the link , enter cab mounts in the search bar and go to page 2, you can buy cast iron arms for $18 ea. far better than the original on the f100's I believe the bigger trucks came with the iron ones
Old Oct 21, 2009 | 07:22 PM
Old F1's Avatar
Old F1
Mid fifty cat.
F-series Cab Mount Arm REAR Adjustable Info 0711 59.00 Each
