Another drywall question.
Old Oct 20, 2009 | 06:43 PM
85e150's Avatar
85e150
I have a guest room on our garage. It's about 15x18, bath, "kitchenette", closet. It has an open, vaulted ceiling. It is insulated, but was not heated or cooled most the time during the last year or so. The drywall at the very peak crumbled and shows signs of moisture and a little mold. I figure my problem was condensation, as during the recent rain, no moisture. My secondary concern is the corner metal used. I can understand the drywall going to pot, but the corner metal is rusted like it sat in salt water for 5 years. I see a little rust coming through in non-crumbled areas.
Isn't that stuff galvanized? Should it rust? If it rusts, how can you put drywall mud on it and not have a disaster?
I'm going to get this fixed, but want to make sure I don't have a bigger problem with all the corner metal.
Thanks.
Old Oct 20, 2009 | 06:53 PM
jake00's Avatar
jake00
I think you have some other issues. My garage is drywalled and not heated or cooled and i've never had mold/moisture/rot
Old Oct 21, 2009 | 12:44 AM
Chaosracing's Avatar
Chaosracing
How long ago was this dry wall installed? There is a huge problem with drywall made in China. Corner bead can rust if left to stay wet long enough. I would double check the roof in the area where you are having these issues. You might have a small leak somewhere as well.
Old Oct 21, 2009 | 01:33 AM
85e150's Avatar
85e150
Drywall was done about 18-24 months ago. I'm going to give the roof another look/sprinkler test. I have drywall (same stuff) in the car part of the garage for the fire barrier. No problems there, but that doesn't get closed up like the guest room.
It's always something.
Old Oct 21, 2009 | 08:13 PM
Chaosracing
Well if the drywall was done that early and you do not find any kind of leaks, I would try and find out where the drywall came from. The chinese drywall is a serious issue.
Old Oct 22, 2009 | 11:41 AM
stormyrider's Avatar
stormyrider
Sounds to me like you have a ventilation issue. Air flow between the roof and the insulation prevents mositure buildup that will cause condensation. The most effective means of controlling this is with the combination of a ridge vent that runs the leanght of the roof peak and soffit vents on both sides of the roof overhang and make sure nothing is blocking this area. It is not uncommon for those that don't know better to try and seal that area with insulation. If this don't fix it a powered gable end vent should, but in 99% of the cases passive ventilation is all that is needed.
ford2go
Aug 29, 2013 06:38 AM
ford2go
21
Jan 21, 2011 01:48 AM
websthes
Nov 8, 2007 09:20 PM
fred_79f250
16
Jul 19, 2007 01:16 AM
