Radiator fans ?
Old Oct 20, 2009 | 05:42 PM
56panelford's Avatar
56panelford
Radiator fans ?
What size and make electric radiator fans are you using in your 53-56's. I am getting my original rad recored and plan using the electric fan pull type, does it need to to cover all of the core to get sufficient cooling?
Thanks in advance for all your cool tips
John
Old Oct 20, 2009 | 09:07 PM
jniolon's Avatar
jniolon
old and in the way
I'm using a hi-perf Spal puller.... 2300cfm I think ??? 16" or so so it pretty much covers the whole rad...
later
john
Old Oct 20, 2009 | 09:20 PM
dongc1's Avatar
dongc1
I have a Spal straight blade fan on mine. Cools real well, with the AC on, even on our 105' days this summer.
The straight blade fan pulls about 300 CFM more air than the curved blade fan. The drawback is that is real noisy. Sound like a mini siren. Don't really notice it going down the road, but when you stop you can hear it. Outside the truck, it is pretty noisy. Don't get a Zirgo fan. I had one and it burned up and the housing melted. Found out after that it was a common problem with them. No problems with the Spal
Old Oct 21, 2009 | 06:37 PM
56panelford
I was thinking of puchasing this one from Jegs Perma-Cool 19126 Perma-Cool Standard Electric Fans or possibly this one but is twice as much money wise
JEGS 52115 JEGS Dual Electric Cooling Fans# trying to figure which would be the best choice or if they are a good choice at all, has anyone here purchased one of thiers to make a comment.
Old Oct 21, 2009 | 09:50 PM
Julies Cool F1's Avatar
Julies Cool F1
Hey Panel, just food for thought. Those electric fans can draw up to 45 amps of current. Make sure your generator/altrnator is rated at at least 85 amps for an electric fan install!
Old Oct 22, 2009 | 07:40 AM
56panelford
Thanks Julie, I'll keep that in mind. I think the one I have pushes at least the much but will check to make sure, thanks
Old Oct 22, 2009 | 09:54 AM
HD74's Avatar
HD74
Here's mine for my 51' with a hopped-up flattie. Flexalite #180 pulls 3300 cfm and only draws 18 amps.[/IMG]
hwyhogg
Jun 28, 2014 05:11 PM
madmax680
1997 - 2003 F150
Mar 18, 2013 11:26 AM
jniolon
Feb 24, 2012 12:15 PM
Flashman
18
Jun 25, 2010 09:58 AM
Ultramagdan
59
Nov 3, 2006 09:57 AM
