broke power steering pump
Old Oct 20, 2009 | 04:53 PM
octaneforce's Avatar
octaneforce
i went to replace the power steering pump return house (the rubber one) on my 1992 f150 4.9l 5spd, and i broke the plastic spout off the pump.i broke the nipple that the hose slips over. question is, can i just replace the back half of the pump? like the reservoir part? if so, how does it come apart? all help is appreciated.
Old Oct 20, 2009 | 04:58 PM
EPNCSU2006's Avatar
EPNCSU2006
You can replace just the plastic reservoir if you can find one for sale on its own. You will have to remove the pressure line and the big fitting it threads into. Then the reservoir will just pull off the back of the pump. It would be a good idea to replace the o-ring between the reservoir and the pump while you have it apart.
Old Oct 20, 2009 | 05:05 PM
octaneforce
alright thanks alot. ill have to find the reservoir. if i cant find it ill end up buying the whole pump and just using the reservoir from it.
Old Oct 20, 2009 | 07:50 PM
g_k50's Avatar
g_k50
Why does it make sense to me to use the whole new pump and put the used one in storage for replacement parts, instead of taking the new pump apart and putting that new reservoir on the old internals? PS, buy a Ford pump not a reman.
