Hey all, I was going to replace the ebrake pads last weekend and when I tried to remove the rotors to expose the emegency brake pads, I found that the rotors were attached to the axel shaft as tight a witch's pituwee!
(Yes the brake was off)
I noticed that they don't provide tapped holes to drive a bolt into the axle flange to "Pop" it free.
:-staun
Any tricks of suggestions would be greatly appreciated!
Thanks .... Paul
