Need Help
Old Oct 19, 2009 | 06:52 PM
mustangmikew's Avatar
mustangmikew
Need Help
I just put a rebuilt 69 long block in my 93 f150 with all the efi on top the only thing thats different is the motor and heads, it has fire and fuel but wont fire, going crazy any ideas.
Old Oct 19, 2009 | 06:53 PM
mustangmikew
and the cam is big
Old Oct 19, 2009 | 07:34 PM
wolfsmurf's Avatar
wolfsmurf
what size engine? if you have fire and fuel and still no start its timing or compression that is keeping it from running.
Old Oct 19, 2009 | 07:53 PM
mustangmikew
it is a 302
Old Oct 19, 2009 | 07:56 PM
wolfsmurf's Avatar
wolfsmurf
i would check and recheck the timing. its easy to get it off a lil bit and unlike those chevy guys us ford guys have to have it really close to get it to run.
Old Oct 19, 2009 | 07:58 PM
mustangmikew
lol true that. i will recheck yet again, would a big cam be causing these problems
Old Oct 19, 2009 | 08:08 PM
wolfsmurf's Avatar
wolfsmurf
i have zero experience with cams and FI. there are lots of others here who may chime in at some point. i would think it SHOULD start up even with the big cam but maybe not run as good as stock?
Old Oct 19, 2009 | 08:12 PM
mustangmikew
thanks for the info, i came to the same theroy about it starting maybe i should change it over to a carb and be done
