air meter sensor (MAF) and processor?
Old Oct 19, 2009 | 11:55 AM
87Mater's Avatar
87Mater
where are these located on a 90 F150. thats what one of the codes are for thet a got. i printed off the test proceger but does not show a location
Old Oct 19, 2009 | 12:01 PM
Lazy K's Avatar
Lazy K
Unless someone has done a serious swap your truck does not have a MAF sensor.
Old Oct 19, 2009 | 12:30 PM
87Mater's Avatar
87Mater
hmm then why does alldata say i do. vary strange. guess it is the trans oil temp then. need to find the test procceger for that
well do you knwo where the MAP is? got a code for that as well
Old Oct 19, 2009 | 12:49 PM
andym's Avatar
andym
Start over.. we can't help you fix your problem if we don't know what's going on. What's wrong with your truck? What codes did you get? How did you pull the codes? If you got a code for a mass air sensor then something is seriously wrong. A speed density computer shouldn't even be able to throw that code.
Old Oct 19, 2009 | 12:54 PM
87Mater's Avatar
87Mater
runs rough and stalls when cold idles at 500rpm and the trans shifts hard and drops out of od (the OD light does not come one)
i got 11, 24, 26, and 81 for codes
i got them by jumping the self test port like it said on fordfuelinjection.com
Old Oct 19, 2009 | 01:04 PM
andym's Avatar
andym
This is why it's important to know whether these are KOEO, CM, or KOER codes.
From the first two codes I'd say that the engine wasn't warmed up when you ran the test. It also sounds like you could have a bad vacuum leak. You might also start with cleaning the throttle body out really good and cleaning the IAC valve.
Old Oct 19, 2009 | 01:07 PM
87Mater's Avatar
87Mater
they where KOEO and the last one showed up when it whent through the CM codes
and it was cold at the time. it was night and my naighbors are sensitive with noise
where is a good spot to put a vac guage? do not want to remove an important line
Old Oct 19, 2009 | 01:18 PM
andym's Avatar
andym
The best place to put a vacuum gauge is to find an unused port on the vacuum tree on the intake manifold and put a piece of vacuum line on it. If there aren't any unused ports you can use the fuel pressure regulator line.
You have to warm the engine up all the way before you run the test.
Old Oct 19, 2009 | 01:20 PM
87Mater's Avatar
87Mater
ok i will re-do the self test then. i will also look at the vacuume wile it is warming up.
also thanks for the help
dj lpm
2015 + Expedition & Navigator
Apr 15, 2016 12:31 AM
xenfinityx
2004 - 2008 F150
May 24, 2015 06:50 AM
spaytons
May 6, 2015 04:19 PM
renchr56
Nov 25, 2009 08:00 AM
rbastedo
Aerostar
Sep 9, 2002 07:51 PM
