Header Problems
Old Oct 19, 2009 | 11:52 AM
Floyd Hammit's Avatar
Floyd Hammit
Header Problems
Hello If I have posted this twice I apologize. I have a 351 Windsor in my 1956 F-100 it also has a Mustang II front end clip. The collectors on my current shorty headers are so close to the motor mounts they are melting the rubber. What headers should I be running or should I go to solid steel motor mounts and if so which ones. Any help will be greatly appreciated. Thanks, Floyd
Old Oct 19, 2009 | 05:46 PM
59flatbedford's Avatar
59flatbedford
im not sure but i would think you would not want solid steel motor mounts as that would not give the vibration from the motor anywhere to go and would end but cracking something. not sure on what headers would work as i have no experiance with your combo. I say just turn um over and run um straight up through the hood. lol
Old Oct 19, 2009 | 06:47 PM
sjahnke's Avatar
sjahnke
Check out the clippster headers at Classic Hot Rod Parts & Accessories for Chevrolets Trucks, Ford - NoLimit Engineering. They look like they might solve your problem.
Old Oct 19, 2009 | 07:56 PM
Floyd Hammit
Re 59 flatbedder
Thanks guys for the suggeestions but the Clipster Headers are real close to what I already have. I need the exhaust to come out in the rear of the headers and not in the center. I may have found a set at BBK Headers.
Floyd
Old Oct 19, 2009 | 08:45 PM
fordgo's Avatar
fordgo
you might be able to solve your problem by making a stainless steel sheet metal shield bolted betweeen the motor mount and the block to divert the heat away from the mounts or maybe a header wrap kit like summit sells
Design Engineering DEI 010121 - DEI Short Roll Exhaust and Header Wrap
The same great exhaust wrap only in a shorter roll.
Design Engineering's short roll exhaust and header wrap is designed to keep heat in the exhaust and evacuate it out of the engine compartment. Wrapping your headers reduces underhood temperatures by up to 50% while providing additional horsepower, engine protection and passenger comfort. These header wraps use a hi-temp fiberglass composite material with a proprietary coating to enhance heat retention and expand durability.
Old Oct 19, 2009 | 10:29 PM
cmoritz's Avatar
cmoritz
Check my Gallery for Pic's off the 351w with BBK headers...I'm happy with the fit..just unhappy there's no soot in them yet...Good Luck!
Old Oct 19, 2009 | 11:50 PM
Julies Cool F1's Avatar
Julies Cool F1
Try The Sanderson Web Site at:
Sanderson Headers - sandersonheaders.com
