9" Gearing
Old Oct 18, 2009 | 04:34 PM
davewave649's Avatar
davewave649
9" Gearing
I have a 9" in my truck however i have no idea if it is original. It has a metal tag on one of the bolts. The tag reads:
WDM-S OCB
3.25 9 313A
Does anyone know what all of this means?
Old Oct 18, 2009 | 06:08 PM
BobbyFord's Avatar
BobbyFord
WDM-S Ford Pickup '63-'72, F-100, 3.25 9in, NL= non-locking, 28 spline.
Old Oct 18, 2009 | 06:31 PM
davewave649
ok thanx for the info. If i want to change the ratio, what all do i need to do?
Old Oct 19, 2009 | 09:06 AM
PROSTOCK's Avatar
PROSTOCK
Take it to a shop that specializes in doing rear ends. Or find the gear set that you want at a bone yard, and swap the whole center section. Setting up the gears is not for everyone.
Old Oct 19, 2009 | 01:45 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
WDM-S OCB: According to the date code, this is not the original rear axle for the OP's truck.
And, there is another factor to consider.
WDM-S: Fits: 1965/69 F100 and 1970 F100 before serial number J30,001.
From serial number J30,001: Ford changed the differential bearings from ball bearings to the Slim Line tapered roller bearing design.
WDM-S: Fits: 1970 F100 from serial number J30.001, 1971/72 F100.
OCB: Assembled the second week (B) of March (C) 1970 (O).
Old Oct 19, 2009 | 07:54 PM
davewave649
the engine in the truck is from a 71 torino, is there any way the rear axle from that car?
Old Oct 20, 2009 | 03:23 AM
NumberDummy
Nope, not with that WDM-S code...it isn't. The WDM-S code is specific to 1965/72 F100's w/a 9 inch.
1970/71 Torino: WEB-T / 9" rear axle / 3.25-1 / non Limited Slip.
