no start when warm
Old Oct 18, 2009 | 09:24 AM
L.A.S.Billy's Avatar
L.A.S.Billy
no start when warm
hey guys, just joined and looked through many questions but not sure if IPR is my problem. Truck is 95 psd stock. The truck sat for a while because of running issues. I've replaced batterys,glow plugs,fuel pump,fuel filter, and flushed old fuel out and cleaned fuel regulator screen. Now to prob. truck will start cold without issues(wouldn't before) but after running for only few minutes no restart,even if try to spray. If i start truck cold and keep idle high it will run but stall as soon as i try to idle truck. and as stated will not restart. Any help before i continue to throw parts at it. thanks.
Old Oct 18, 2009 | 12:33 PM
Action4478's Avatar
Action4478
Welcome to FTE .. You most likely have an internal High pressure oil leak , start with the small o ring on the end of the IPR , then if need be , use a gauge to test the pressure to the heads (injector O ring )...
Old Oct 18, 2009 | 04:09 PM
MADVAN's Avatar
MADVAN
X2 on its a oil leak issue.
Bill
Samuel Poynter
Jan 15, 2017 08:13 PM
snowdog79
Aug 2, 2016 11:23 PM
jlinn06
May 5, 2016 03:21 PM
VR666
13
Jun 16, 2015 11:14 AM
dlbrooks2658
New Member Introductions
Nov 21, 2007 01:19 PM
