Vibration Between 66 & 68 MPH
Old Oct 17, 2009 | 02:28 PM
SHOpar's Avatar
SHOpar
Lately I've noticed a faint vibration from the rear of the truck right between 66 & 68 mph. It is really minor, but still annoying, as I usually cruise around that speed on the freeway towing my trailer. The truck is completely smooth at all other speeds above and below this range.
I'm thinking either one of my rear tires has gotten slightly out of balance or the rear driveshaft wasn't bolted up at the same spot when the shop pulled the tranny and replaced the clutch a few weeks ago, so now the driveshaft is slightly out.
I'm going to take the truck in and get the tires rotated and rebalanced today, but what do you guys think? Does this sound more like a driveshaft or tire balance issue? Hopefully it turns out to just be out-of-balance tires, otherwise do I need to take the truck to a driveline shop and have them rebalance the driveshaft? How much would this run me?
Thanks!
Old Oct 17, 2009 | 03:17 PM
DRRXR's Avatar
DRRXR
Msb
Thanks!
Mine did almost the same thing when I rebuilt the tranny. Mine was either the Mid ship bearing or the u-joints. Mine made a whine at 40 ish. Changed everything out and it went away.
Rocky
Old Oct 18, 2009 | 09:41 AM
SHOpar's Avatar
SHOpar
I crawled under the truck yesterday and noticed the shop didn't bolt the driveline up the same when they reinstalled the trans, but that was a quick 10 minute job to unbolt it and realign it. I don't think that was my problem though.
When I took the truck in to get the tires balanced, the guy at the shop said he noticed one of the rear tires they rotated to the front had some side-to-side tread wobble when he had the tire on the balancing machine. He said it was pretty minimal, but to let him know if I noticed it, and they will replace the tire.
Sure enough, as soon as I hit 35, the steering wheel starts shaking a little and the whole truck vibrates. The tire shop is closed until Monday, but I'll be calling them first thing tomorrow morning to have them order me a new tire.
Old Oct 26, 2009 | 02:43 PM
DRRXR's Avatar
DRRXR
Other
Thats not good, if the wear on the tire is from the rear end wear and not old front wear; then you may have a problem with the rear axle where it penitrates and attaches to the wheel hub. If that is the case then the vibration from that are is magnified towards your differential and wears out the clearances and then you have repair issues there as well. Then if the tires are not properly aligned and balanced you can get wooble from that or if your ball joints are going bad. Here is a few other threads on this issue:
https://www.ford-trucks.com/forums/8...+end+vibration
https://www.ford-trucks.com/forums/858394-help-still-slight-vibration-in-shaft.html?highlight=rear+end+vibrationhttps://www.ford-trucks.com/forums/858394-help-still-slight-vibration-in-shaft.html?highlight=rear+end+vibration
https://www.ford-trucks.com/forums/7...+end+vibration
https://www.ford-trucks.com/forums/6...+end+vibration
https://www.ford-trucks.com/forums/4...+end+vibration
https://www.ford-trucks.com/forums/8...ight=vibration
Rocky
Old Oct 26, 2009 | 03:16 PM
SHOpar's Avatar
SHOpar
I got the new tire installed on Saturday and it cured the vibration. No more shaking of the steering wheel and the truck rides smooth as can be all the way up to and beyond 75 mph, so I'm happy!
I asked the guy about the defective tire, and he said it was a manufacturer defect and that it is a pretty common problem they see across all brands and types of tires. As with any manufacturing process, there's always going to be some product that rolls off the assembly line that isn't perfect.
Old Oct 26, 2009 | 03:46 PM
DRRXR's Avatar
DRRXR
Good 4 U
Glade to hear it did not get in your pocket.
mjtpolice76
Apr 13, 2015 10:49 PM
Gastic3514
Jan 20, 2013 09:08 PM
MobyDick22
1997 - 2003 F150
Jun 2, 2012 09:29 PM
Joe Finn
1997 - 2003 F150
Mar 16, 2007 10:42 PM
