Sponsored by: Real Truck
grinding noise
Old Oct 16, 2009 | 07:30 PM
broozerthehoundog's Avatar
broozerthehoundog
grinding noise
Had a bad grinding noise in front end of f 250 hd when decelerating with ttb d 50. Spider gears were broke . Friend had dana 60 solid axle,so I swapped. All I had to do was use my hubs and discs. I still have bad grinding noise in front end when decelerating. Nothing else was used from front end of mine.
So my question is, "do the wheel bearing hubs go bad?"
Shortened and balanced drive shaft,
New axle u joints, wheel bearings and lockout hubs.
thanks
jim
Old Oct 16, 2009 | 07:42 PM
mrford60's Avatar
mrford60
you dont say how many miles on your truck, but the hub bearings do go bad.
Old Oct 16, 2009 | 07:50 PM
broozerthehoundog
wheel bearings and lockouts are new
Old Oct 16, 2009 | 07:53 PM
broozerthehoundog
the only part in common used, was the hubs. there is no noise unlocked . when hubs are locked wow what a grinding sound.
Old Oct 16, 2009 | 07:59 PM
mrford60's Avatar
mrford60
what year is your truck and what year is the rear you put in? you got me stumped!?
Old Oct 17, 2009 | 07:10 PM
broozerthehoundog
96 f250 . What I'm wondering is do the splines in the hub go bad ? Everything else is new.The hubs have 90000 on them. I'm talking front end also.
Old Oct 17, 2009 | 09:23 PM
mrford60's Avatar
mrford60
did you replace the small roller bearing that the axle rides on? you have to take off the rotor then take off the hub that the rotor rides on and inside that hub is a small roller bearing that the axle rides on. that bearing could be dry.
Old Oct 17, 2009 | 11:53 PM
EXv10's Avatar
EXv10
Take the hubs apart and take a look, it should be quieter locked unless there is a problem in the locking hubs or diff. Sure it's not in the T-case?
Old Oct 26, 2009 | 05:48 PM
broozerthehoundog
it was the needle bearing in the spindle.
thanks evryone
jim
Old Oct 26, 2009 | 06:12 PM
mrford60's Avatar
mrford60
those get overlooked alot
Old Oct 26, 2009 | 08:16 PM
EXv10's Avatar
EXv10
I thought you said you replaced the wheel hubs.
Old Oct 26, 2009 | 08:20 PM
mrford60's Avatar
mrford60
you can replace the hubs without getting near the spindle needle bearings
Old Oct 26, 2009 | 08:33 PM
EXv10's Avatar
EXv10
I guess we are talking about 2 different hubs, i said wheel hub not locking hub, and there is no spindle, just a stub axle in the knuckle.
Old Oct 26, 2009 | 08:44 PM
mrford60's Avatar
mrford60
he is also working on a 96 f250 not a super duty, they don't have a sealed hub bearing thay have a bolt in spindle shaft that the stub axle rides in. when he said he replaced the hubs i took that he ment the lock out hubs.
Old Oct 26, 2009 | 11:07 PM
EXv10's Avatar
EXv10
Saying what he had would have been good.
