Last weekend while climbing hill at ranch right front tire was not engaged.
Both front hubs were locked in while in 4wheel low, standard trans.
Both rear wheels spinning as well as left front. Any ideas on the problem and as always all help is greatly appreciated.
Thanks,
Bart
That is normal, the front is an open diff, if both front were to pull a the same time you would have a very hard time steering when making a turn, when making a turn the out side tire will turn faster than the inside tire as the outside has farther to travel.
