Flashing check engine light.
Old Oct 15, 2009 | 07:17 PM
feeties's Avatar
feeties
1998 F150
5.4
159000 miles
Ok so I've had my check engine light on here for about 3000 miles, ran the numbers took it in, it was a bad bleed valve on my fuel pump. However at the time I didnt have time or money to replace it so I was waiting till next monday. Well on my way home the check engine light started flashing so I turned it off, opened hood, let it sit then started it up and it stopped flashing.. What does this mean? As of now I am no longer driving truck till I get the problem worked out.
Old Oct 15, 2009 | 08:44 PM
torkum's Avatar
torkum
A flashing CEL is almost always a COP going bad.
Old Oct 16, 2009 | 07:46 AM
galaxie641's Avatar
galaxie641
When the CEL flashes it means the problem is immediate, as opposed to vacuum leaks, misfires or dirty sensors that set a solid CEL. Either way you need the codes pulled before we can say what the problem could be.
Old Oct 17, 2009 | 09:21 AM
projectSHO89's Avatar
projectSHO89
A flashing CEL is the PCM's indicator that you have a SEVERE misfire - most often caused by a failed COP as torkum said.
Pull the codes - the DTC will tell you which cylinder(s) may be suspect.
Old Oct 17, 2009 | 08:30 PM
juan0214's Avatar
juan0214
What's a COP?
Old Oct 17, 2009 | 10:48 PM
projectSHO89
Coil-on-Plug
JimmiesVixey
Mar 1, 2017 08:03 PM
ImAGirl
Aug 3, 2015 03:13 AM
rideracelivemx7
Apr 18, 2011 06:42 PM
grip1968
Apr 6, 2011 10:50 PM
akidagin
Dec 10, 2007 01:00 PM
