The truck is bone stock from the factory. The smoke from the tester was leaking out on the passenger side rear area. Like I said before couldnt really see it very good. My friend/mechanic automatically said IMRC then said he would have to tear into it so he could actually find the exact problem.
Can the brake booster vac line be accessed with out removing the intake manifold? I have dont have much time during the week to look at it and with the time change its not very light outside when I got home making it that much harder to see.
I did notice that just before the booster line goes behind the intake it turns into a steel line I believe. If this is the case does it turn back into rubber hose somewhere between the hard line and intake?
