Recommended scan tool
Old Oct 15, 2009 | 03:21 PM
80skeys's Avatar
80skeys
Can someone recommend a scan tool for my '88 F150 302. I'm a do-it-yourself mechanic and would like to be able to retrieve scan codes and test procedures.
Thanks.
80skeys
Old Oct 15, 2009 | 03:25 PM
wolfsmurf's Avatar
wolfsmurf
actron makes decent ones relatively cheap and found at most parts stores.
Old Oct 15, 2009 | 04:39 PM
quicklook2's Avatar
quicklook2
innova 3145 is my choice.
avail on ebay, do a search.
it is electronic and is way better then any i saw in parts stores.
Old Oct 15, 2009 | 05:05 PM
EPNCSU2006's Avatar
EPNCSU2006
If you're set on getting a reader, that's fine, but just in case you didn't know, you can run the same tests and get the same codes using only a paper clip or jumper wire.
EEC IV Self Test hookup
Leave out the test light/analog volt meter in the diagrams on the linked page and count the blinks on the check engine light.
Old Oct 15, 2009 | 06:10 PM
apb's Avatar
apb
I just got an Actron CP-9190 which seems to do ok. It will datalog as well as do STAR tests. It was $265 at Amazon. You can get readers for less but this one seems to do anything you would need on obd1 fords plus it will do the latest obd2 stuff also.
Old Oct 16, 2009 | 07:51 AM
TexasGuy001's Avatar
TexasGuy001
I have the innova 3145. It has a digital display, and is not expensive. I'm happy with it.
I didn't know that Actron made one that would do OBD I and OBD II. We have an Actron OBD II unit and it is nice.
Old Oct 17, 2009 | 02:48 PM
80skeys's Avatar
80skeys
Awesome. I like that.
I didn't read your post until after I bought a scanner! But that's okay, I got a cheap actron for $30 on ebay. We'll see how it works for me. I don't want to spend $200 on a scanner - that's 1/5 what the truck cost me!
80skeys
19
Jun 13, 2010 09:47 PM
80skeys
Jun 12, 2010 03:05 PM
80skeys
May 27, 2010 10:06 PM
80skeys
Oct 29, 2009 04:54 PM
80skeys
Oct 9, 2009 03:17 PM
