Lifter knock
Old Oct 15, 2009 | 01:54 PM
cognac54's Avatar
cognac54
Lifter knock
Greetings everyone, i own a 1999 e-150 with 240,000miles on it. My serpentine belt broke and it ran hot for just a quick second, replaced belt then my lifter or lifters starting knocking,any ideas what i can do without replacing my engine. Thanking u in advance
Old Oct 17, 2009 | 08:20 PM
cognac54's Avatar
cognac54
Its not the lifters
I took off the belt and started the van, the knock that i thought was the lifters, had completely stopped. What could that knocking noise be when the belt is on?
Old Oct 23, 2009 | 08:31 PM
alvaroguillen's Avatar
alvaroguillen
i have a knocking problem also- does yours get louder or change depending on your speed?
or is it constant?
Old Oct 23, 2009 | 08:43 PM
YoGeorge's Avatar
YoGeorge
It's got to be something driven by the belt. Bad bearings in the idler pulley, loud power steering pump, a/c compressor clutch, alternator....
If you can get the belt on quickly, listen to stuff at the front of the engine with a piece of heater hose or something and you should be able to isolate. Or feel the bearings in the idler and other accessories with the belt off to see if there is any looseness/play or binding.
George
Luke MacIntosh
Feb 9, 2016 01:59 AM
TooHuge
2004 - 2008 F150
Feb 1, 2016 01:32 AM
19704X4F250
16
Jan 1, 2013 09:15 PM
MRStace84
Nov 14, 2012 08:29 PM
shizuka
Jan 14, 2003 11:23 AM
