Sponsored by: Real Truck
Hi all
Old Oct 15, 2009 | 11:03 AM
044x46.0's Avatar
044x46.0
Hi all
I am a newbie here. So hi all. My 04 6.0 has problem with a no light on the water seprator. The truck stalled twice and i found that i had bad fuel. I drained it some water came out out it, but if it is enough to stall the truck should the light be coming on? Has anyone else had this problem? Thanks Rick
Old Oct 15, 2009 | 11:34 AM
Lubbockguy1979's Avatar
Lubbockguy1979
The factory type filter has a water block membrane to prevent water from passing. Hopefully you changed the filters with racor, international or ford parts. I'm not sure about the wif warning light. I would keep a eye on the fuel you are getting there is a hfcm? Drain to check every 5-10k per the owners manual. I haven't had a wif issue to date but I do change my filters every 15k+/-
kbuchheit
Jun 25, 2021 11:44 AM
LIGOOMBA
16
Aug 24, 2010 03:17 PM
kcroyal23
1983 - 2012 Ranger & B-Series
Aug 28, 2006 11:34 PM
WilliamCH
Oct 28, 2004 11:42 AM
visegrip
Nov 13, 2002 07:41 PM
