Need info on 351c
Old Oct 15, 2009 | 08:45 AM
robjs111's Avatar
robjs111
Need info on 351c
Anybody have any info or point me in right direction for info on a 351C motor with casting numbers:
2 brl carb. intake: D3AE-9425-__
L- exhaust: D1ZE-9431-AA
R-exhaust: D2DE-943D-BA
Carburator tag: D5TE ATA
B 5C 20
any hlp would be appreciated.
thanks.
Old Oct 17, 2009 | 08:41 AM
mustang81's Avatar
mustang81
Because the 429 Cobra jet and Super Jet were available only in Mustang, Cougar, Torino and Cyclone, only a handful of casting number will be found. Most common are D0OE-9430-A (right-hand) or D0OE-9431-A, D1ZE-9431-AA, D1ZE-9431-CA1, D1Z1-9431-CA2(left-hand). More left-hand types are listed due to different applications.
D0AE-D blocks have two-bolt mains. D0AE-C and D3ZE-A blocks have four-bolt mains. This information enables you to identify these blocks without pulling the oil pans. 1970-74
Old Oct 17, 2009 | 09:36 AM
mustang81's Avatar
mustang81
Pull one valve cover and look for numbers, this will give me a good idea what you have. 2v or 4v head ? aluminum intake manifold or iron. If you want more information about your 351, give me the more information you can give me, anything will be helpfull. if you pull the oil pan look for crank number and connecting rod bolt end shape.
Old Oct 17, 2009 | 02:06 PM
johnboy427's Avatar
johnboy427
The casting numbers on most cleveland heads is on the bottom of the intake runner, you will need a mirror to see it with out pulling the head. The carb is no off a cleveland it is a 75 model and cleveland production stopped in 74. It looks like you have something that was made out of a lot of different engines. The exhaust manifolds have been replaced for sure. Your intake is a stock iron job, but you could have a 400 and not a 351C, you can check the block casting numbers that are located right above the starter and that will tell you if you have a true cleveland or not. You could still have some more missmatching but pull the numbers off the heads and the block and you should know about every thing you need to.
-Johnboy
va hunter
Jun 15, 2024 03:38 PM
Redneckfordf2502002
Apr 6, 2016 11:10 AM
Gary Lewis
33
Mar 9, 2016 09:13 PM
blitzkrieg469
23
Dec 10, 2015 08:09 AM
hellraiser
Jan 12, 2004 02:14 PM
