T-18 Shifter Linkage
Old Oct 15, 2009 | 03:20 PM
FordBuddy09's Avatar
FordBuddy09
brand new transfer case too
Old Oct 15, 2009 | 03:46 PM
bghnkinf250's Avatar
bghnkinf250
Short bed? I do not think those were available in the F250s. Something does not add up. Not to sound like a downer, but I hope the owner did not do the work himself. If he is mechanically inclined and did the work himself, then he should be able to diagnose the problem.
I am not trying to rain on you, but I just want you to be informed and prepared when you go to talk with this seller.
Old Oct 16, 2009 | 12:46 PM
FordBuddy09
well its a 6ft bed and normally i call it a short bed but idk. the only reason he told me he can't really fix the problem is that he is in college and he just has never no free time to do anything and also that he don't know what the exact problem is, he thinks its either the clutch pressure plate or the clutch linkage
Old Oct 16, 2009 | 01:51 PM
andym's Avatar
andym
Ford did not make anything shorter than an 8' bed on an F-250 in 1983.
Sounds like the previous owner is clueless. Again, don't trust his diagnosis.
Old Oct 16, 2009 | 02:14 PM
FordBuddy09
ok alright im just trying to figure out things like i said i know nothing about ford
Old Oct 16, 2009 | 02:27 PM
bghnkinf250
Neither did I, but they are not all that hard to learn. All we are trying to tell you is to go in there with a very critical eye, and do not trust what he says. If it has a 6 foot bed and is badged as an F250 from this era, he is tryingto get over on you (unless the frame is shortened, at which point, run). You might actually make out in the deal too. Just go in to the situation as educated as you can about the differences between the F-150's and F-250's so you can see any visual cues. If he does not have time to adjust a mechanical clutch (I think they had them then) but has time to replace a transfer case and do the other stuff, there is a problem.
It could turn out to be a deal, but none of us want to see you get cheated. Just educate yourself as well as possible.
Old Oct 16, 2009 | 02:40 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Only the 460 and the 6.9L diesel had a hydraulic clutch in 1983.
1953/96 F250's have 8 lug wheels on a 6.50" bolt circle.
AFAIK, no F250 Regular Cab ever came with a short bed.
If it's a 1983 4WD with a short bed, it has to be an F150 since (1980/83) F100's were not available with 4WD.
F250 badges: The front fenders may have been changed.
Get the VIN from the seller. Once it's decoded...that will tell what is it. The 5th, 6th and 7th digits of the 17 digit VIN represent the series.
Old Oct 19, 2009 | 04:17 PM
FordBuddy09
yeah. that may be true but im really hoping to go and see the truck in person so i really know what it is and if it runs and shifts nice and easy but if i do get the truck i will change the linkage into a cable like how my dad had on his truck
Old Oct 19, 2009 | 04:53 PM
andym's Avatar
andym
Good luck with that.
ZachH
17
Nov 5, 2016 05:00 PM
liftnw8z
Pennsylvania Chapter
1291
May 31, 2015 09:25 PM
HIO Silver
16
Oct 19, 2014 09:42 AM
TheMechanicalAnimal
22
Aug 21, 2012 11:59 PM
texasyeti
Sep 15, 2009 06:35 PM
