Sponsored by: Real Truck
BullyDog CHIP
Old Oct 12, 2009 | 08:25 PM
ToppCon's Avatar
ToppCon
Question BullyDog CHIP
I bought a 6 pos chip and am trying to install it. I took all the glue and plastic off the comp board contacts w/400 grit sand paper. I then cleaned both surface pins w/mineral spirits. I put the chip in and turn the key-- and my tach doesn't work, check gages light is on, check engine lite on, glo-plug lite stays on. I can start it and it runs at idle. If i try to move, LURCH LURCH. I checked and re-checked the contacts to make sure they were clean. Bad BullyDog? Anybody have a suggestion?
Old Oct 12, 2009 | 08:28 PM
freekyFX4's Avatar
freekyFX4
Probably better off asking this in the forum for your appropriate engine than in the super duty thread.
https://www.ford-trucks.com/forums/forum167/
Old Oct 13, 2009 | 11:07 AM
jdadamsjr's Avatar
jdadamsjr
Whew, I would pull it RIGHT NOW, and think twice about putting it on my truck again....
frying your pcm would NOT get you the performance you want !!!!
Have not been fond of chips ever
