73 cooling fan bearings
Old 10-11-2009, 09:11 PM
spudgunman's Avatar
spudgunman
spudgunman is offline
The cooling fan on my truck is wobbly and seems to clack a bit, I couldn't find any parts in LMC anyone know if this is a easy fix or replacement. any tips on where to find replacement parts
Old 10-11-2009, 09:12 PM
Jermafenser's Avatar
Jermafenser
Jermafenser is offline
Which type of fan do you have?
Old 10-11-2009, 09:18 PM
spudgunman's Avatar
spudgunman
hrm. its a 5 Fin, F250 Camper Special XLT no AC need anything else more specific?
Old 10-11-2009, 09:19 PM
Jermafenser
Uh...is it a belt-driven fan or does it have a fan clutch on it?
Old 10-11-2009, 09:22 PM
spudgunman's Avatar
spudgunman
oh sorry, belt attaches to the water pump I believe. No clutch.
Old 10-11-2009, 09:24 PM
Jermafenser
Are the bolts tight? Any bends? Pulley ok? If they all are ok, it's your water pump.
Old 10-11-2009, 09:40 PM
spudgunman's Avatar
spudgunman
so it was, just ripped it off, thanks for the help! awesome site. so another Q related, how much play is ok on the pump? I took the fan off and spun the pump and no gritty or smashed bearing feel i can wiggle the arm around like 1mm or so. (the arm is the shaft thing that the fan and pulley attach to)
Old 10-12-2009, 04:46 PM
spudgunman's Avatar
spudgunman
I wiggled it and then it started leaking so figure the seal or bearings were bad, for 40 bucks no reason not to replace it. THanks!
Old 10-12-2009, 05:14 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
With the engine OFF use both hands and wiggle the fan blade back/forth.
If there is ANY play...AT ALL...It's time for new waterpump.
Old 10-12-2009, 09:32 PM
spudgunman's Avatar
spudgunman
yup, that's what I had, Thanks to this fine forum in helping detect the problem before it blew up on me. I just finished replacing it and smell like orange clean!
