A stupid question ?
Old Oct 11, 2009 | 07:52 PM
ozzy_2_me's Avatar
ozzy_2_me
A stupid question ?
I know it may sound stupid but were the h***. is the Hazard/Warning Flasher located?
Some people say that it is on the back of the fuse box but the only one i seen on or near the fuse panel is the turn signal flasher. I have no Hazard lights. and i am trying to fix this issue.
Old Oct 11, 2009 | 08:36 PM
JimsRebel's Avatar
JimsRebel
It is directly behind the turn signal flasher, just swap them for a quick test.
You would not see it if it was taken out by the PO.
Jim
Old Oct 11, 2009 | 10:31 PM
FordNFishinLover's Avatar
FordNFishinLover
Think you talkin about the the Large round fuse found on the fuse box inside the cab? Its to the left underneath your dash.
Old Oct 12, 2009 | 02:22 AM
Sycostang67's Avatar
Sycostang67
There are two flashers on the fuse box. The one on the front is for the turn signals, the one for the hazards is on the back of the fuse box (between fuse box and firewall). It can be difficult to see or remove. There are only 3 bolts(I think) holding the fuse box to the firewall. You can pop it off real quick if you need to. As was mentioned a PO could have removed it. If the turn signal flasher dies, some people will just swap in the other flasher and never replace the bad one.
Old Oct 12, 2009 | 07:11 PM
ozzy_2_me's Avatar
ozzy_2_me
yeah, today on my lunch break i unscrewed the fuse panel from the firewall and i did not see any flasher. But after a closer inspection i did see a similair plug as to the flasher. So i plugged in a new HD flasher and Low-and-be-hold they work. first time in years i have working hazard lights. Thank you guys for the help.
