Front cab supports 48-52
Old Oct 10, 2009 | 03:44 PM
john fin's Avatar
john fin
Some questions for those who have done front cab supports:
1. Can they be replaced while the cab is on the frame (ie how to support the cab)
2. How hard are the old ones to remove. They look spot welded to a bunch of items.
3. Does someone sell the upper floor board (firewall)repair panel?
Old Oct 10, 2009 | 05:59 PM
51PanelMan's Avatar
51PanelMan
1. Can they be replaced while the cab is on the frame (ie how to support the cab) I don't see why not. I'd loosen the rear and run a strap through the door opening, then lift up with an engine hoist or similar device. You can leave it suspended like that or put some wood between the cab and frame.
2. How hard are the old ones to remove. They look spot welded to a bunch of items. Drill out the spot welds or remove with a die grinder.
3. Does someone sell the upper floor board (firewall)repair panel? Not that I know of. Check with EMS Metal.
Old Oct 10, 2009 | 07:45 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Keep in mind you need to cut out all the way to solid metal. From your previous pictures, the patches sold aren't going to get you there.
Old Oct 10, 2009 | 09:59 PM
john fin's Avatar
john fin
floor boards
Ross, I was going to replace the floor and support together. There in an indent for the support in the floor so I need to go with the combination. Looks like I will have to patch the upper part of the floor board. If the metal was not so thin I could patch the whole floor, its bad but not too bad, but its really thin.
Old Oct 10, 2009 | 10:04 PM
thendrix's Avatar
thendrix
Bitchin products offers a full replacment firewall if that helps. It is not stock. It has a 2" setback (I think) and is smooth.
