Batterys????
Old Oct 10, 2009 | 03:29 PM
gradyc's Avatar
gradyc
wellhead
Batterys????
Hi guys. Need your help..
01 F250 was getting hard to start. Replaced fuel filter and checked each battery. One batt 12.54v other batt 12.67v. Cycled fuel pump a couple of times to make sure fuel bowl full. With volt meter on batterys and after the wait to start light off and while cranking the volts went down to 8.6volts.
I know it takes at least 10.50 volts for the engine to start.
I am going to pull the batterys and take to autozone and have them load tested.
If they check out OK. Could the starter be the problem?
Grady
Old Oct 10, 2009 | 03:57 PM
pbr man's Avatar
pbr man
If they load test OK, check your clamps and post. I just went thru this a couple of months ago-batteries down on charge,hard start, wouldn't hold a charge. I took everything apart, scrubbed the posts and clamps, washed everything with a baking soda solution. When I got everything back together and the batteries charged, it worked like a champ---until yesterday.
I checked the batteries and the post looked good, but there was a film across the top of the batteries which was causing a discharge. I pulled the clamps off and there was a white corrosion between the post and the clamp. I took the batteries out and did a baking soda solution on the trays, cable, clamp, and batteries. I reinstalled with a dielectric grease underneath and around the clamps and posts, which I hadn't done before.
Even though the clamps looked good, the corrosion was building up between the clamp and the post and not letting the battery take a charge, thus discharging over time until it wouldn't start. I think that created some kind of electrolysis and caused some sort of vapor the come out of the battery and build up on the surface and create more problems.
Old Oct 10, 2009 | 05:09 PM
gradyc's Avatar
gradyc
wellhead
Thanks Eric,
I cleaned the battery posts about a week ago and it didn't help the slow start. I am going to check the ground connection here in a little while.
We are visiting my Daughter here in North Texas for a few days. The Girls are out shopping so it will be awhile before I can get the batteries (thanks, can't spell anymore) checked. The batteries are 34 months old and have a three year warranty on them. Hope the girls get back soon.
Grady
Old Oct 10, 2009 | 05:13 PM
4inchlovin's Avatar
4inchlovin
I agree with Eric about checking ALL the cables. Including the wire on the starter. But 34 months old for batteries isnt exactly brand new. If they load test ok then I would start cleaning.
Old Oct 10, 2009 | 07:40 PM
pbr man's Avatar
pbr man
When you cleaned the posts, did you use a wire brush? When cleaned mine the first time I just used a stiff bristled brush with the baking soda, and they looked good. It wasn't until I really scrubbed with a wire brush that I could really see how much they changed from a dull gray to a shiny silver. That was when I saw a big improvement in the starting and holding a charge.
Old Oct 10, 2009 | 07:42 PM
megawatt00's Avatar
megawatt00
Instead of die electric grease use Noalox. It is an oxide inhibiting compound that is also electrically conductive so it will prevent corrosion and also all the current to flow.
Old Oct 10, 2009 | 08:09 PM
pbr man's Avatar
pbr man
Aw.. does that mean I have to clean the dielectric off and start over
That is what they gave me at my local NAPA store today when I was working on the batteries.
It says on the tube "For all electrical connections to prevent voltage loss from arcing, suppress radio frequency interference, dissipate heat, insulate connections, and seal out moisture. Use on GM modules, Ford rotors, spark plug boots, marine light sockets and other connections."
I put it on today and everything seems to be working well, and am thinking if it seals out the moisture and the air, it should stop the corrosion as well.
Old Oct 10, 2009 | 08:14 PM
megawatt00's Avatar
megawatt00
No it will work but if it starts to corrode or give you problems again then the Noalox is the way to go. You can buy a tube of it at HD or Lowes in the electrical isle. You clean the posts and clamps like normal then put it on the post put the clamps on then if you want a little on the tops of the clamps and posts. The auto parts stores don't carry it because it is an electrical specific product. I had suggested it to a few members here and they have used it with great results. I had a friend that salted the roads in the winter for the state and anytime we had to repair the wiring on the sander the connection got some Noalox. Those connections never had a corrosion issue.
Old Oct 10, 2009 | 08:47 PM
pbr man's Avatar
pbr man
That is good to know. I have used the dielectric on all my light connections on my Kenworth and Peterbilt trucks for years with great results. I figured if it worked on those connections, which were exposed to a lot of road grime, it would work on the batteries, where they are not exposed to all the road chemicals.
Old Oct 11, 2009 | 10:29 AM
gradyc's Avatar
gradyc
wellhead
UPDATE.
It's Running!! One of the batteries was a little low on H20 in one cell. Topped it off. Took them to Auto Zone for a charge and load test. Both were ok.
Will pay closer attention to my batteries in the future.
Thanks for all the help and info. You guys are awsome!!
Grad7y
